بنده در Zend Framework بسیار بسیار تازه واردم.
قصد داشتم از طریق $.post در jQuery، ردیفی را در db حذف نمایم که هرچه کردم نشد.
در Google و Youtube هم بسیار سرچ کردم ولی نتیجه نگرفتم، متاسفانه.
ZF version: 1.11.2
application/Bootstrap.php:
protected function _initDb(){ $con=array('host'=>'127.0.0.1','username'=>'root','password'=>'','dbname'=>'sample_db'); $db=Zend_Db::factory('Pdo_Mysql',$con);$db->query("SET NAMES 'utf8'"); Zend_Registry::set('db',$db); }
applicationcontrollersDashboardController.php:
public function indexAction(){ $this->_helper->layout->setLayout('a');}
applicationviewsscriptsdashboardindex.phtml:
<a href="javascript:deleteTest('62989c12369ea3c1')">DELETE</a>
publicjs0.js:
function deleteTest(id){ if(confirm('Are you sure?')) $.post('http://127.0.0.1/Sample4/application/models/Guestdb.php',{funcName:'Delete_Test',id:id},function(r){alert(r)})}
applicationmodelsGuestdb.php:
<?php class Model_Guestdb{ public function Delete_Test(){ $db=Zend_Registry::get('db'); $r=$db->query("DELETE FROM `prac` WHERE `id`='".trim((new Zend_Filter_Decrypt(array('adapter'=>'mcrypt','key'=>'thisisakeytolock','vector'=>'myvector')))->filter(hex2bin($this->getRequest()->getPost()['id'])))."'"); echo$r?'t':'f'; }} $a=new Model_Guestdb(); if(isset($_POST['funcName']))call_user_func(array($a,$_POST['funcName'])); elseif(isset($_GET['funcName']))call_user_func(array($a,$_GET['funcName']));
Output:
Fatal error: Uncaught Error: Class 'Zend_Registry' not found in C:\xampp\htdocs\Sample4\application\models\Guestdb.php:6 Stack trace: #0 C:\xampp\htdocs\Sample4\application\models\Guestdb.php(35): Model_Guestdb->Delete_Test() #1 {main} thrown in C:\xampp\htdocs\Sample4\application\models\Guestdb.php on line 6
پیشاپیش ممنون
